I erred yesterday by backing into a hedge that had the invisible Bell phone box hidden in there (not the pale green one but a steel one, must be old).  Anyway damage was done, I have the larger of the broken pieces but at the moment haven't found the small one.  I am looking at Gorilla tape from behind as the temp repair.  Is the small third rear bumper panel available or does one have to get the whole unit?  Any available?
They were available separately. I had one changed 10 years ago after getting rear ended.  I believe the new one will be black and requires painting and a hole drilled to pass the wire for the marker light.  Check with Glenn in London (Smart142) you may get lucky and find a red one.
  • 3 months later...
I had damage to the same panel when i was rear-ended at a stop sign a few years ago. Since I had replaced both rear fenders with ones that had no rear light pods (brought them back from Europe in my checked luggage around 2007). I was concerned that any replacement would have the hole pre-drilled. The body shop was able to get an unpainted panel in the European specs (no hole). So it looked good as new. These days there are probably a number of smarts sitting in auto "junk yards" for salvage.
