clarknova Posted September 30, 2025 Posted September 30, 2025 (edited) 2005 Fortwo CDI This car gets driven daily and never had a problem starting until this morning. When the key is turned on, all the dash lights come on as usual. When the glow plug light goes out, I attempt to crank and nothing moves. I hear a click like a relay that sounds like it's coming from in front of me. The voltage dips only slightly, like from 13.0 to 12.8 (this is with a 3.5A charger having been on it all day). I also hear a humming from behind me for a few seconds. I tried earlier today with a booster pack as well as with booster cables from a running vehicle. Same result. I've ruled out a current problem at least to the battery cables. So then I connected an iCarSoft 2 and looked for fault codes. Nothing. All the live data appears to be normal as far as I can tell. If the starter died, it was sudden. I never heard it fail to engage in the past. If the starter was seized wouldn't it bring the voltage down significantly while trying to crank? With the minimal voltage drop I'm seeing I don't think there is any significant draw beyond maybe the glow plugs and the ECU itself. What to look at next? I'm not sure what else to try before giving up and towing it to a shop. Edited September 30, 2025 by clarknova spelling Quote
Nigel Posted October 1, 2025 Posted October 1, 2025 Try to give the connector for the start signal on top of the starter solenoid a wiggle. It can get some corrosion on it, a very common problem in this area. You can reach it from the top with long needle nose pliers or forceps. If that works I’d spray some Krown or Rust Check on it to slow down the corrosion. Nigel Quote
