cloggedb Posted January 29 Posted January 29 Unseized a very seized alternator. Now it will crank but not start Does probably have old summer fuel so I'm thinking maybe with the cold lately it might be gummed up. Any other ideas? https://youtube.com/shorts/2rIT781tBkI?si=YiANs-2WB2lg7-tv Quote
LooseLugNuts Posted January 30 Posted January 30 stick a heater under the back....or a magnetic block heater on the oil pan for a few hours to give it a better chance diesel 911 would be good to add if you suspect gelled up fuel 1 Quote
LooseLugNuts Posted January 30 Posted January 30 she doesnt sound very even on the compression when cranking ...skips... but its been a while since ive heard one crank...it sure sounds slow and cold 1 Quote
Nigel Posted January 30 Posted January 30 Scott, can you hear the in tank pump run when you turn the key on? 1 Quote
cloggedb Posted January 30 Author Posted January 30 2 hours ago, LooseLugNuts said: she doesnt sound very even on the compression when cranking ...skips... but its been a while since ive heard one crank...it sure sounds slow and cold It's been a very cold few weeks . Quote
cloggedb Posted January 30 Author Posted January 30 2 hours ago, Nigel said: Scott, can you hear the in tank pump run when you turn the key on? I'm trying to remote mechanic for my mom, she's the one with the car and got it unstuck. She tells me she hears a buzz for about 5 seconds when turning key and she's pretty sure it's the fuel pump but I really need to go and listen for myself to confirm Quote
MikeT Posted January 31 Posted January 31 Check the N-111-3 connector on the SAM. If one or more of the pins show heat damage, the car needs external relays mounted. 1 Quote
cloggedb Posted January 31 Author Posted January 31 3 hours ago, MikeT said: Check the N-111-3 connector on the SAM. If one or more of the pins show heat damage, the car needs external relays mounted. I'll have her go look once it warms up a bit. I'm kinda hoping for burnt pins. Quote
cloggedb Posted February 15 Author Posted February 15 Got my mom to do a few quick checks. Sam looks to be in great shape. And the connector for the fuel pump looks good. I hope to have her try and record fuel pump noise when she goes out to put the sam back in. Will try and crank again now that it's not so cold out. Anything else I should look for or get her to record? IMG_20260214_215035.heic Quote
cloggedb Posted February 15 Author Posted February 15 (edited) Ok looks like there is a bit of a fuel leak on left side of the car. Reading up about where it's dripping looks like a high pressure fuel pump leak. Would this leak stop the car from starting? Edited February 16 by cloggedb Quote
cloggedb Posted February 19 Author Posted February 19 Got a video from my mom of the leak Seems like a high pressure fuel pump if it's dripping there https://youtube.com/shorts/SNZABlV_WdQ?si=YE3q-L014njUQUg8 Quote
cloggedb Posted August 29 Author Posted August 29 Does anyone have a guide on getting to the high pressure fuel pump and removing it? I'm going up to my mother's soon and would like to take it off and switch with a known good pump from my running car Quote
Specter Posted Thursday at 01:05 PM Posted Thursday at 01:05 PM If you open the air filter box and spray some quick start that will tell you if it's a fuel problem otherwise it could be a stuck crank sensor issue. just a thought Quote
stickman007 Posted yesterday at 12:04 AM Posted yesterday at 12:04 AM A much more definitive way is to just hook up to a scanner and monitor the rpm of the crank sensor while cranking. Starter fluid will work, but also have the potential to cause damage. Quote
