Occasionally I'd get the 3-line hamburger in the centre of the display and the car wouldn't accelerate or shift. So I replaced the clutch actuator and took out the slack with the key on and the transmission in gear before bolting it down. 90% of the time the car operates and shifts perfectly, but occasionally I still get the hamburger menu icon or it will say it's in 6th gear but not engage the clutch. When this happens I pull over, turn the key off and then on, and move the shifter in an out of gear a few times until the car decides it's ready to start again. Usually this problem happens when transitioning from acceleration to deceleration (coast).
I have two of these cars and they're both doing the same thing. I've was planning on replacing the clutch actuator on the second one, but maybe that's not the cause of the problem. What should I be looking at next?
Edited by clarknova
On my fist smart I took mine out and really cleaned it and filled it up with white lithium grease and after it shifted much better.
I have soldered the connection points in a sam before to fix bad joints but it is a bit of a job. Maybe you can find a electronic repair place to have a look.
I'd also wait for one of the smartcar experts to chime in they'll have much better ideas than me haha
  • Thanks 1
Izzy (stickman007) is probably the most knowledgeable guy on the forum with the electronics on these cars and he is in the Edmonton area.  He does service some of the Edmonton area members cars at his home so reach out to him. He is quite busy and doesn’t always check the forum regularly but is quite quick at responding to messages.
