Hello Hive minds!
I just picked up a '13 451 at auction.  Had a dead battery.  Once powered up with a new battary, no start. Has the "Three Bars of Death" and a locked gearshift, do not hear the actuator move. No brake lights.
Pulled the codes:
P0500  vehicle speed sensor malfunction
U0146  Lost coms with central gateway mod
U0122  lost coms with vehicle dynamic control mod
U0103  lost coms with gear shift mod
U0100  lost coms with Engine control mod
U0001  lost coms with canbus
P0947  TCM low voltage
P00FF  misc garbage code
What I have done so far:
I've removed the SAM and resoldered some maybe suspect joints, checked all fuses / connections, reinstalled.
Replaced brake switch (thats a pain to do!).  Still no brake lights.
Pulled the drivers seat and checked the shifter module for water damage.  Dry of all watermarks, connections clean.
Checked grounds by battery and SAM, checked visable wiring for breaks and damages.
hooked up a booster cable between negitive post and engine block (just in case). Still no start, 3 bars and locked gearshift.
I need more ideas to check over!  My mind is not up to the task Lol.
Edited by Ravk
added content
