Location: Near Calgary right now, but moving far, far, far, far, far, far, far, far, far away ASAP.
I think 06 Jun 2006 is 06/06/06
Well this is what my computer says: (i copied and pasted the following text)
ilovemysmartfortwo
purist 100+
Interesting. On my display I copied and pasted from your avitar area. I wonder why we are seeing different times unless it is a time zone thing. Here is a pix of what I see
I see the same as RichHelms. What is your "Time Zone" set at? Click on the "PROFILE" link at the top of the page. Mine says GMT - 4 hours for the Atlantic Time Zone.
ARTZ, you should be GMT - 3 during Daylight Savings Time:
reference
Toronto is GMT - 4 during Daylight Savings Time.
Outside of DST, remove an hour (Fredericton would be GMT - 4 and Toronto would be GMT - 5). For now at least, you have to manually select your time zone adjustment on this board.
I see you joined on 05 Jun 2006 as well. You probably joined when it was midnight in one of the Canadian time zones. :P The board stores time as possibly an exact time, not an actual date, so it depends on what everyone's time zones are set at in their settings.
But the last post column... shouldn't it have the date the last post was added? Isn't that where they said they were having the 06/06/06 problem? It is probably just a coincidence that their join date is similar.
-Iain
yup, my computer's clock is set right.
And I think I did join close to midnight my time on June 5/06 so thats probably why.
In my profile it says GMT - 8 hours, but then right below it, it says:
Date format:
The syntax used is identical to the PHP date() function. 06/06/06 12:53
So maybe I should take out the 06/06/06 12:53 cuz I can delete it and put what I want there :dunno2:
Date format:
I just checked my profile, and it has D M d, Y g:i a in the date syntax. (I let it default when I set things up)
Your joined date on your avatar showed up as up as 05 June 2006 until I changed my timezone, now it is 06 June 2006.
MG
If you change your time zone to Ontario time (like i did), it will show 666.
I didn't post a reply (what you're reading now) at the time you think I did.
