Follow-up on my attempt
In august 2007, in warm weather, my car seemed to be more economical on fuel. So I decided to give a final attempt at my goal of 2.2 li/100km. But the result was not that much better, so I didn't publish the numbers. I even discarded the details just to keep the general results. So here it is.
I kept the same rules as the first attempt, but did it on 2 days in a row instead of 5½. I run the same «route» twice on august 11 and 12, but this time going toward Montréal instead of down the St-Lawrence river. I went from St-Jean-Port-Joli to St-hyacynthe on the hyway and back on rural roads. Wind was almost non-existent one day and light to «moyen» next day. Against my will, the wind helped somewhat by being light going (headwind) end stronger on the way back (tailwind). That's the usual patern of the wind, starting light in the morning and growing stronger as the day goes on. I also did a super filing by jacking the rear of the car. I thought I would run out of fuel close to home with around 45 km on 0.0 li showing on the display, but it didn't bother me, being close to home.
Here are the results:
1184 km, on 25.8 liters for 2.18 li/100km, almost 130 mi/gal.
So I did get 2.2 but with so much pain that I will never do that again in the same conditions. Keeping at or below 60 kmh on the hyway was sometimes dangerous the closer I came to Montréal and denser traffic. I had to go on the side many times so not to be possibly rear ended. And the way back on rural roads going thru villages and small towns on sunday's traffic was a pain. ( Don't try it at home ... lol !)
Warm weather is a real help ( was between 25 and 30, even higher on asphalt ). Wind helped on one day too, even if I respected my own rule of return trip on the same day. These numbers should be very hard to improve, without aerodynamic mod to the car. Driving 1184 km with so much attention to any small detail is a real killer, beware of headaches.
Edited by Serge
  • Replies 66
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Agreed! Very impressive! Serge, what have you found to be the *ideal* cruising combination of road speed, engine load, etc, to get maximum efficiency? Is there a sweet spot, or do you keep modulating the throttle all the time and just try to get the lowest consumption on the ScanGauge?
Ca C'est magnifique!Congratulations Serge you must be one steady guy to have such control for so long.I drive moderately and am pleased to get to 4.0 ratrher than my regular 4.4 so I cannot imagine getting down to 2.18.It just shows what can be done. Now if you were to have a Hybrid Smart......
Good show Serge. That is an amazing result. I have tried it myself a few times but, I never get numbers like that. I know how difficult it can be dealing with the other cars on the road. I was wondering which model you have. My option loaded passion cabrio never gets the milage that my old non A/C pure coupe did. Now with wider wheels and tires, there's no hope. I would think that an option free pure coupe would be the ultimate hypermiler.
Thank you all for your congrat... I didn't talk about this last summer because it sounded crazy and I felt kind of miserable. Almost a year later, I can look at it calmly now and your comments make me feel a little better.
Well Duck, you're much too kind with your ultimate respect..... I felt more crazy than respectable !!!!! It is ultimate driving though , pushing to that low limit is kind of extreme sport. Anyway at the time, my life fuel average was 3,21 and will go up since last winter I drove around Mike's average of 3,9.
The aim of this attempt was to find how low we could go down on fuel economy with this fine smart car. And I found the bottom ( mine at least).
Booneylander wrote « Serge, what have you found to be the *ideal* cruising combination of road speed, engine load, etc, to get maximum efficiency? Is there a sweet spot, or do you keep modulating the throttle all the time and just try to get the lowest consumption on the ScanGauge? »
With gas engine, there is always a sweet spot like the most efficient RPM for a particular engine in high gear and low speed. Since diesel engine get their rpm from richer mix of fuel/air ratio, the lowest rpm gives the best FE. So the driving technique is quite simple, lowest rpm in 6th gear at lowest speed so not to fight too strong wind. With the smart, this simple equation is difficult to achieve because of the automatic change of gear at too low a speed. In practice one has to keep speed around or below 60, try not to change to 5th gear, anticipate uphills by speeding somewhat or change gear at the best time when necessary. I never let the shift down arrow appear on the display more than a second or two except on downhill when the funny arrow tells to downshift without necessity. The most steady trottle is best... no modulation. That's where my trottle control lever is usefull. 2seatragtop said that Serge must be one steady guy.... yes He must be to achieve that 2,18 but otherwise not that steady guy in life....
In real driving it goes like this : every other second check speed below 60, check mirror to see who is coming at the back and at what speed, 59 kmh ... too fast so put load down from 45 to 42, check rpm on SG, whoops going down to 1230, must up LOD to 44, rpm to 1255 ok. Small incline push lod to 54 right over the slight hill, try to regain what was lost on the up, going down on lod 0 , a stop ehead.... must slow down at the right spot so not to change gear too fast, no car coming in open field so pass stop in 3rd gear, accelerate very slowly but fast in economical 5th gear at 1050 rpm.... and so on.....
Diesel Dave, my car is a basic pure coupe with two wooden bumpers that might interfere with wind ( not that much I suppose). Let me tell you on the last attempt, temperature inside went sometimes pretty high without AC and windows closed for better airstream, but I couldn't resist the use of the cooling fan most of the time, loosing some points in FE.
Cher Smartzuuk,
Tu as parfaitement raison, ce genre de «performance» n'est d'aucune utilité en usage quotidien de la smart. C'est d'ailleurs pourquoi je me suis désintéressé de ces résultats l'été dernier, et cessé de faire ce genre de folies !!! Ce n'était qu'un exercice poussé à l'extrême pour voir les possibilités de la voiture. Je crois qu'on aime tous cela de temps à autre, pousser nos limites extrêmes. Pour moi, tu as été une inspiration à faire ce genre de folies. ;)
Je crois cependant fermement aux voitures le plus écologiques possibles, mais pour être véritablement écologiques, les voitures doivent être grand public utilisées en usage quotidien normal. C'est pourquoi j'observe attentivement le développement rapide des voitures électriques et je serai sûrement un des premiers propriétaires dans quelques années. ( 2010 annoncent toutes les compagnies, on verra bien). B)
Si nous vivions dans la même province, jamais je n'oserais affronter le grand Smartzuuk qui a accompli tant de choses. Je m'inclinerais volontiers lui laissant les lauriers et la couronne du vainqueur !!!! Je lui donnerais mon accélérateur manuel avec plaisir et garderais le gros marteau imprimé sur ma tête !!! :lol::P:D
Serge
I agree; but I think it's going to be next to impossible without software or something. Unless we buy that pedal that Glenn has for sale and modify it to have a switchbox to the real pedal (cumbersome) and take out the return springs, pedal, guts - everything except the relationship between the two pots... and put a knob on that.-Iain
I found that under these conditions, shifting down, as advised by the car's computer, dropped consumpion from perhaps .5 LHK to 0 LHK on the Scangauge.
  • 1 year later...
Yes there is a risk for safety because it stays on as long as we don't pull back the lever. But it is not that bad since I forgot it on a couple of times and, on braking, I didn't even saw a difference, except that the transmission changed gears and the car re-accelerated lightly on leaving the brake pedal. I wouldn't suggest it to anyone in normal driving, sure not in city driving. It is usefull only on FE challenges. It is a temporary set-up ... but...... I like it so much that I might make a permanent one.
Concerning the safety of the hand trottle lever..... I discovered yesterday that there is no safety concern about it..Trying to brake while keeping the gas pedal depress, I fund out that the computer cuts the gas while applying brakes. Found something new on my smart after 3 years of experiments. So, about safety, there is no problem keeping the hand trottle on while braking.
That's nice to know, since I now have to use hand controlled brake and accelerator for medical reasons, and it's possible to apply both at the same time. The instructor told me that the operation of a car with adaptive controls is regulated; I had to undergo a series of instruction and practice before the occupational therapist would issue the prescription that allowed the installer to mount the hardware in my car. If an insurance company were to find that unauthorized hand controls were in use at the time of an accident, the company could deny a claim. That's the law in Ontario as I understand it. My throttle control doesn't stay "on" unless pressure is applied to the control knob. I use cruise control if I want to take my hand off the control and cruise along.
The cruse control operates exactly as it did before. The throttle knob of the hand control is normally left in the "off" position when cruise is activated. A light press forward on the knob applies the brakes and deactivates the cruise control. Again, as before, if I rock the knob back, I can accelerate past the cruise's set speed if I want to. There is no dead man's switch. I simply control the brake and throttle with my left hand. For a short 20 second video and further explanations click here.
  • 15 years later...
