Recent Posts
Sounds good - main thing is to make sure the tool angle and the flare fitting angle match - even a degree out makes a big difference. Cheers, Cameron
Good to hear. I have an SUR&R hydraulic flare tool but have failed to get the cunifer lines I've made up to seal when attempting to do a pressure bleeding. I could imagine that you'd be able to tell me what I'm doing wrong, if nothing else! So yeah let's connect sometime maybe in spring? Cheers Mike
Hey Mike - glad some of the original crowd is still around. We are up in Mill Bay now. Our smart is over 280k I think now - almost catching up to the Jeep. Gerri was looking at a CLA but we opted for a 2017 Chevy Volt - works perfectly for her and most of the miles are done electrically. I can do line flares (thanks to my old school mechanic Dad teaching me). If it is imperial line I have the flaring tool (just have to find it) and know how to do double flares for steel line, been a few years so I might need to practice a couple times first. The trick is to be patient and not heavy handed (and put the fitting on before you do it!). As long as I don't have to install them - crawling under cars is no longer a thing for me after my back went (it is fixed and as long as I respect that it doesn't want me looking at the under side of cars, it won't remind me of bad life choices for a week or so!). I have a couple of tech tips I should write up - like cleaning EGR valves using an ultrasonic cleaner - makes them look/work like new! As well as how to repair your rear window washer when it starts leaking on the inside of the window, very poor design, easy fix if you know what is going on (and as a side bar - how to re-assemble the rear hatch if you take it all apart including the right order of cuss words to get it to all go back together - there is a reason they replace the whole unit if the rear window breaks...) Good to hear from you! Cheers, Cameron
By smartnhappy · Posted
“Tough times never last, only tough people last.” Charles Leclerc - F1 driver
Member Statistics
Who's Online (See full list)
- There are no registered users currently online
